Re: more on 404 no spark problem
Posted by gene bender on December 28, 2006 at 10:24:09 from (67.55.226.214):
In Reply to: more on 404 no spark problem posted by eharmon on December 27, 2006 at 20:38:33:
if it just up and quit maybe you better take the dist cap off and then using the starter see if the rotor turns camm mite have srtipped a tooth or even crank could have broke i had one not too long ago turned over wouldnt start had a busted crank. Another one stripped teeth in the cam dist didnt turn.
