Re: Super A Steering Gear Lube
Posted by City-Boy McCoy on December 28, 2006 at 12:03:04 from (68.221.177.31):
In Reply to: Super A Steering Gear Lube posted by SuperA-Tx on December 28, 2006 at 11:13:17:
I would agree with what Mark said in his answer to your question but would add a little more... The top plug to my steering gear box is vented through a tiny hole in the side, right about the top of the pipe threads. I did not see it at first because it was hidden by dirt, paint and grease. Also, I encourage you to use Cornhead grease, available from most tractor dealerships. Unlike many other greases which can be "stiff" and waxey, Cornhead grease is a very "wet" grease and will lube the steering gears well without allowing an air pocket to form between the teeth, which would not allow sufficient lubrication. Cornhead grease also maintains a very constant viscosity throughout normal temperature ranges. It is not expensive and comes in grease-gun tubes. It won't leak anymore than any other grease. I have had excellent results using it.
mike
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
