Re: Super A Steering Gear Lube
Posted by Bob on December 28, 2006 at 15:54:54 from (69.178.229.154):
In Reply to: Super A Steering Gear Lube posted by SuperA-Tx on December 28, 2006 at 11:13:17:
If the seals are not the best, and you don't want to replace them at the moment, use CORNHEAD GREASE. It's GREAT for steering gears.
I flows a bit, to lube better than thicker grease, get doesn't drip as quickly out of leaky seals as oil does.
I pick it up at the DEERE dealer, but I would think CNH must have something similar.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
