Re: H seeping oil
Posted by D Slater on December 28, 2006 at 17:50:40 from (152.163.100.65):
In Reply to: H seeping oil posted by Elk Farmer on December 28, 2006 at 12:30:31:
If it is leaking oil from under head most times its from run back oil from rocker arm area going down push rod holes on way to pan and seaping out, most times on right side. I usualy find someone has reused headgasket when it happens. Pressure passage to rocker arms is near center of block and to right or camshaft side of block. If leaking there i don't think it would make it to front of block to come out. As another poster said make sure oil is not coming from higher up and running down.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
