Re: 300U NEED HYDRAULIC PUMP
Posted by SIMO on December 29, 2006 at 05:40:08 from (158.52.254.237):
In Reply to: Re: 300U NEED HYDRAULIC PUMP posted by JayWalt on December 13, 2006 at 08:51:12:
JWALT, I WORK DAY SHIFT AS A MAINTENANCE SUPERVISOR FOR ALL OF ASSEMBLY AND PLASTICS DEPT.
I LIVE ON CR 216. YOU PROBABLY GO TO WORK THAT WAY. MY BUDDY TORE HIS PUMP APART AND FOUND SOME BAD SEALS ("O" RINGS). HE RE-INSTALLED THE PUMP, HAD PROB"S GETTING IT STARTED. MESSED WITH TIMING. CLEANED THE GLASS BOWL. STARTER LOCKED UP, AND RAN THE BATTERY DOWN. SO HE WALKED AWAY FOR A WHILE TO COOL DOWN. I THINK THE SEALS MAY TAKE CARE OF HIS PROBLEM. IF NOT, I DO HAVE A PUMP I DON"T WANT TO GET RID OF....BUT I MAY MAKE HIM AN OFFER AS A LOANER W/CASH THAT I CAN BUY BACK IF MINE FAILS. LOOK ME UP WHEN YOU GET BACK TO WORK YOU LUCKY DOG,AND WE"LL TALK TRACTORS.
STEVE SIMON EXT.6073
