Re: Gear Selector - 1066
Posted by TN1066 on December 29, 2006 at 08:29:14 from (199.190.8.11):
In Reply to: Gear Selector - 1066 posted by TSH on December 29, 2006 at 08:10:10:
There is a roll pin at the bottom of the vertical shaft right at the top of the speed transmission. It sounds like that pin is sheared. I had to replace the one on mine and I got to it by removing the right side battery and going in that way.
