Re: Farmall H Liftall Coupling
Posted by Haas on December 29, 2006 at 10:25:25 from (12.65.36.212):
In Reply to: Re: Farmall H Liftall Coupling posted by Gary Puckett on December 28, 2006 at 18:42:00:
The dealer is not correct. Both of them are right hand thread. To get the one off the transmission countershaft, put the PTO in gear and then use a PTO shaft on the splines to lock the shaft in place. Then insert a bar though the slot in the coupling nut and apply some torque in the appropriate direction. If that does not do it, a few sharp raps with a hammer on the bar should break it loose. Since the operating torque is in the direction that tightens the coupling, they can be really tight and hard to break loose.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
