Re: Super C leaking carb
Posted by 504-1 on December 29, 2006 at 21:25:52 from (64.70.24.67):
In Reply to: Re: Super C leaking carb posted by spray004 on December 29, 2006 at 19:55:21:
No,if the needle leaks gas is going to run till it fills the air filter and can flow up through the valves and past the piston rings and into the oil pan.
