Re: GM 1-wire VS GM 3-wire???
Posted by Bus Driver on December 30, 2006 at 05:38:13 from (66.44.245.93):
In Reply to: GM 1-wire VS GM 3-wire??? posted by City-Boy McCoy on December 29, 2006 at 16:51:45:
The acid on top is a possible indication of overcharging. When it is charging, check the voltage across the battery terminals. It should not exceed 14 volts.
