Re: Engine Swap
Posted by ChadS on December 30, 2006 at 08:25:44 from (66.228.96.230):
In Reply to: Re: Engine Swap posted by RustyFarmall on December 30, 2006 at 05:36:43:
If you use the 350 flywheel, you have to use a super H clutch disk, and/or a Super H pressure plate, The 350 pressure plate can work,,, but you will have to adjust the throw out bearing closer to the clutch fingers. SH-350 had a 10.5" diameter clutch, H's had 10" Dont know for sure on the starter ring,,, they interchange, but the 350 may have had different teeth,,, Chad
