Re: New type spark plugs
Posted by John T on December 30, 2006 at 20:10:40 from (66.244.90.5):
In Reply to: New type spark plugs posted by Charlie M on December 30, 2006 at 16:16:01:
Charlie, If you use an electronic ignition coupled with a high energy coil youre gonna get better combustion initiation and you may even gain a few HP on a Dyno. That ignition consistently discharges more energy across the plugs gap (to better ignite the fuel) then the old points n condensor.
If you use a plug adapter and a different plug I suspect you would gain NOTHING, might??? even loose some since the expolsion waveform may be altered or less efficient, not sure of that but Im pretty sure you would gain NOTHING versus a better chance of some gain from an electronic high energy ignition.
John T
John t
