Re: W-9 Questions
Posted by P Backus on December 31, 2006 at 12:41:55 from (69.130.221.148):
In Reply to: W-9 Questions posted by Red48m on December 30, 2006 at 10:18:08:
If your tractor has fuel pump on it, the motor has been replaced
with a crawler motor, or just a factory "crate" motor, set up with
the pump. I"d just bypass the pump, or take it off. Those pumps
were common and can be rebuilt easily, or go to NAPA and get
new diaphragm material and rebuild it yourself.
Paul
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
