Re: Need in Depth Technical Help for my charging s
Posted by John T on December 31, 2006 at 12:51:27 from (66.244.90.5):
In Reply to: Re: Need in Depth Technical Help for my charging s posted by JayWalt on December 31, 2006 at 12:05:21:
Then if its NOT ALREADY I would use the LOAD terminal on that VR to feed hot batery voltage up to the BAT input terminals on the lights or ignition switches versus if they happen to be fed off the ammeters load terminal now??? i.e. just uhhook from the ammeter and wire instead down to LOAD on the VR. You got anything wired to LOAD on the VR now or what??
John T
