Re: International 1586 Digital Dash
Posted by CMayo on December 31, 2006 at 13:56:45 from (65.240.57.80):
In Reply to: Re: International 1586 Digital Dash posted by IaGary on December 31, 2006 at 12:24:48:
The EGT function does not work correctly, it displays numbers that run all over the place. If its cold outside, below about 30 degrees the display is very dim and the first digit never changes from 0. I've had it out and it looks like it is a refurbished unit. Whoever had it before me must have been pretty rough on it as soome of the screws that hold the display together are stripped. the RPM function works OK as does the ground speed and PTO speed. If you tap on it after first starting the tractor the display brightens up and reads RPM, PTO, and Ground Speed correct, but the EGT still does not work as it should. I have an analog pyrometer on the tractor that works just fine but would like to have a completely functioning digital dash unit.
