Re: While We Are Talking Generators
Posted by Bob M on December 31, 2006 at 15:46:53 from (69.205.124.61):
In Reply to: While We Are Talking Generators posted by John M on December 31, 2006 at 15:24:37:
A couple quick tests: 1 - Ground the generator ARM terminal. Then use a 6 or 12 volt battery to supply current to the FLD terminal (ground thru the generator frame). If the armature spins the generator is probably OK. 2 - Ground the FLD terminal. Now spin the armature to 1,800 RPM or faster and take a voltage reading between the ARM terminal and the generator frame. An output reading of 18 volts or higher means the generator is OK. Note - The above will tell you whether or not a generator is completely DOA. However a generator can pass the tests but still have problems with low output, etc.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
