Re: H Farmall part
Posted by kfox on January 01, 2007 at 00:32:47 from (63.18.235.148):
In Reply to: Re: H Farmall part posted by Bob V on December 31, 2006 at 16:27:28:
This bracket also holds the radiator shutter control crank. I think I've read that the very early models had the shutter crank mounted on the rear gas tank support. Must be the ones before 70410. ken
