Re: stright pipe?
Posted by Hugh MacKay on January 01, 2007 at 02:20:01 from (216.208.58.185):
In Reply to: stright pipe? posted by voger213 on December 29, 2006 at 19:06:34:
voger: I see a problem with your proposal. If your going to run a straight pipe, it should be just as long as the mufler. Short pipes will burn valves.
An old gentleman I knew used to run his mufler loose enough so he could lift it off at garage door. He kept a pair of welding gloves just inside the door, slipped mufler off and left it outside.
