Re: IH 1586 Problem
Posted by Janicholson on April 12, 2009 at 15:48:00 from (66.173.50.24):
In Reply to: Re: IH 1586 Problem posted by AE on April 12, 2009 at 15:29:30:
Smell can be pretty defining. Coolant is sweet smelling, oil/combustion products smell sour and petroleum like. If it is loosing coolant. I would remove the oil cooler and test it under pressure (75psi on the oil side of it) to see if air leaks into the water side. (I think it can be a pretty common problem, and cheap to fix!!) JimN
