Re: Stuck Sleeve
Posted by JayWalt on January 01, 2007 at 13:17:58 from (24.223.138.48):
In Reply to: Stuck Sleeve posted by LinemanFarmer on January 01, 2007 at 09:22:23:
If the piston is still in it, u might be able to throw some dry ice in there. It should cause the sleeve to shrink and might break it free. I read this tip on this forum, but it was to remove the piston from the seeve, this might work on a sleeve stuck in the block as well. Good luck and keep up updated on how it finally does come out...
It might help others in the future.
