Re: magneto kill switch on B
Posted by Bob on January 01, 2007 at 16:44:30 from (69.178.229.154):
In Reply to: magneto kill switch on B posted by Wisconsin Cowman on December 31, 2006 at 22:51:51:
Whatever you do, use an original switch, or a GOOD substitute.
If you use some cheap @%%*& switch not made for the purpose, and it gets a little damp and/or gets some conductive dust in it, it will bleed off some primary current from the mag, and make for a weak spark/hard starting/poor running tractor.
There is quite a peak-to-peak voltage put out by the mag's primary circuit in normal operation, and attenuating it with a poor quality switch is NOT a good thing.
