Re: timing? 230? plug gap? electronic ign.
Posted by John T on January 02, 2007 at 06:23:58 from (66.244.90.5):
In Reply to: timing? 230? plug gap? electronic ign. posted by t.r.y. on January 02, 2007 at 04:14:41:
The best plug gap is a question better answered by the electronic ignition vendor dependant to some extent on the coil used and the electronic switch and compression n fuel and other stufffffffff. That being said, often when an electronic ignition switch is used and coupled up with a high energy high voltage coil a wider plug gap is uded versus the old points n condensor ignition. Generally the electronic ignition and high energy coil allows for more energy to be expended across the plug gap to better initiate the combustion and the elec. ignition and high voltagd coil is capable of arcing current across that wider plug gap. Nowwwwwww its often the case where an elec ignition might run say a 0.035 up to even 0.045 or more versus say 0.025 with the points n condensor stock ignition, so if the vendor doesnt offer plug gap recommendatiosn Id just experiment starting at around 0.035. The timing is again, dependant on RPM and fuel used n compression etc but if all else (compression n fuel n RPM etc) is unchanged from stock, I dont see where the timing would be changed much from what was best using the points n condensor. The point gap and cam and follower wear affects timing versus the elec switch where a magnet passing by the pickup coil is what triggers the spark and it dont change like when points wear. However, when adjusting timing using a timing light n rotating the distributor till she fires at a certain BTDC at a certain RPM, you can still get her to fire the same timing as using points. I think theres a general misconception that advancing timing is some sort of a cure all and performance gainer buttttttt its really dependant mostly on RPM and compression n fuel and too far advanced actually hurts performance and may even harm the engine. As far as HP versus RPM and timing I think the only way to tell for sure is to hook her up to a dyno under load n adjust the timing n see what happens. BOTTOM LINE the plug gap will likely be a lil wider (try 0.035 and 0.040 and up) but the timing would still be what it was before if youre still at the same basic RPM and fuel n compression. As far as "lugging" that occurs at a lil lower RPM and the distributors centrifugal RPM sensitive timing advanse ought to still work the same as with the old points as the base plate (where pickup coil replaces points) still rotates the same. Ol John T and all in Indiana NOT an IHC man but believe this to be true regardless, Im curious what the more expreienced IHC guys have to say??????????
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
