Re: H Lift-All not lifting
Posted by Janicholson on January 02, 2007 at 14:23:26 from (66.173.50.63):
In Reply to: Re: H Lift-All not lifting posted by Chad Koel on January 02, 2007 at 14:04:02:
The pump can be disconnected and not working. Also it is necessary to have the transmission turning to make it work. That means the clutch must be out with it in Neutral, or the tractor can be in gear moving. If it is atopped and the clutch is in it will not lift.
The drive for the pump is under the tractor behind the wierd shaped projection with the keyhole shaped holes in it. It is necessary to remove a tin cover plate to see it. If it is missing parts to drive the pump, they can be found easily. Good luck, JimN
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
