Re: Still no attempt to start
Posted by John T on January 02, 2007 at 19:08:50 from (66.244.90.5):
In Reply to: Still no attempt to start posted by ToddH on January 02, 2007 at 17:38:09:
Todd, All there is on that starter circuit is the battery n cables n starter switch n starter. Nowwwwwww it sounds like the cables n batery are alllllllllllll okay correct??? (If NOT check all of them n load test the battery and insure its good and its charged) Sooooo if the battery n all cables n grounds are good but no cranking that only leaves the switch n starter. Id isolate the switch or starter first by by pass jumping around the starter switch i.e use jumper cables from the hot ungrounded battery post direct down to the starter post or starter side of the switch n see what happens????? If she cranks then but NOT via the switch, its either a bad switch or a bad cable or connection on the switch. If she still dont crank even when you hot wire by pass with big jumpers direct to the starter, then it must be the starter. That allllll being said, the same problem can happen if theres even one single bad ground or cable or connection you know, sooooo Id remove, clean n wire brush, n reattach each n every battery n starter n ground n switch connection FIRST ALSO if the ground cable is on any thin or rusty sheet metal component, try reatatching it to a solid clean heavy frame bolt location, that may be the problem. FINALLY my guess is its the starter switch or else a bad cable or connection. In general if when you depress the starter switch the lights dim way down badly and/or the battery voltage drops drastically, THE SWITCH IS OKAY BUT THE STARTERS BAD However, if when you depress the starter switch the lights dont dim much and the batery voltage dont drop much, Id say the switch is bad. Hope this helps??? lemme know Ol John T and all in Indiana
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
