Re: Yes, as soon as starter is hit the ammeter goe
Posted by Nat 2 on January 03, 2007 at 06:44:11 from (64.80.110.27):
In Reply to: Yes, as soon as starter is hit the ammeter goes to posted by ToddH on January 02, 2007 at 18:34:55:
If the cable ends have been replaced with those clamp-on types, you also need to take those apart and clean them really well. Sometimes, it even helps to clip the cable back and strip some fresh wire to insert into the clamp.
Do what we did in troubleshooting mine:
1. Use one side of your jumper cables to bypass the hot wire running from battery to the starter switch. If tractor starts, clean the hot wire cable connections.
2. Use one side of your jumpe cables to bypass the ground wire running from the battery to the frame. If the tractor starts, clean the ground cable connections.
