Re: propane fueled M
Posted by Janicholson on January 03, 2007 at 12:56:19 from (66.173.50.62):
In Reply to: Re: propane fueled M posted by Lee @ Elk Mound on January 03, 2007 at 09:18:13:
Fifth gear is modestly easy to repair, no split. The top off of the trans, the clutch shaft removed, and the fromt carrier with the gears on it come out the front. Keeping all the little rollers is done bu putting a cloth under the shafts where they seperate, and or tieing them with a string wrap as it comes apart. 4/5 slider, and constant mesh need to be replaced. JimN
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
