Re: I need help with a F20 overdrive aux trans !!!
Posted by Old-F20 on April 12, 2009 at 16:18:48 from (71.7.98.117):
In Reply to: I need help with a F20 overdrive aux trans !!! posted by Randy Yearton Jr. on April 12, 2009 at 13:01:52:
Randy Yearton Jr. said: (quoted from post at 13:01:52 04/12/09) You cant put this on if you have it all assembled on the bench, due to there is no way to bolt the case to the trans with it assembled. Do you have any idea where I can find the gear adaptor that goes one the clutch output? It look just like the one im holding in the pics.
i meant put it in with all the shafts in place. of course you cant bolt it one with the outer cover on, duh.
lucky would be the term i would use if you can actually find a replacmenet gear for that. might have to have a machine shop make one.
