Re: Farmall 400 Blue Flame
Posted by Mark Ollila on January 03, 2007 at 22:38:02 from (67.149.203.149):
In Reply to: Farmall 400 Blue Flame posted by Steve Weathers on January 03, 2007 at 17:45:06:
Steve,
If you think your problem is spark timing, I would suggest the Case/IH tune-up specification booklet as a place to start for your tractor's ignition settings. When I check and set ignition timing for the first time on a specific tractor, I try to determine the engine's configuration. For example on an IH C-264 engine, what pistons does it have -- flat top, fire-crater, high altitude? Which cylinder head -- one for kerosene, gasoline, LP-Gas? Also, what spark advance curve is in the distributor? This needs to match the engine configuration. When I think I know the configuration and the engine otherwise looks mechanically sound, I then use the Case/IH tune-up book to make ignition settings. Since most of us don't know the actual history on many older tractors, "customized changes" in an engines past can create "interesting" problems. A good tractor mechanic is handy to have around at such times. Especially, one familiar with the tractor model in question. Hope this helps some.
Mark
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
