Update and thank you
Posted by ToddHt on January 04, 2007 at 06:51:39 from (12.148.189.25):
In Reply to: Still no attempt to start posted by ToddH on January 02, 2007 at 17:38:09:
Hi, I disconnected the battery and jumped it directly to the starter. When I pushed the starter button, the starter turned but it did not engage the ring gear. Now as I type I wonder if I had the pos and neg cables reversed (I’ll have to try again this evening). With the Battery connected directly to the starter, the ammeter again went slightly neg with ignition switch pulled but went back to zero when I pushed starter button. I then removed the battery to look into the control box and I noticed the ignition switch has one wire coming from starter and one going to regulator but also a broken one which I assume went to a fuse but the fuse holder rusted away. But I assume this fuse is just for the lights and as long as this broken wire isn’t touching ground it should not be affecting the ammeter going to zero when ign switch is pulled. I guess I should use an ohm meter next and touch ground and the ends of each ignition switch to see if a lack of insulation is allowing part of a Negative wire to touch the positive ground. Thanks so much for all your past help and any future comments! ToddH
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
