Re: Farmall 504 Transmission
Posted by Weldon K on January 04, 2007 at 12:20:21 from (71.28.74.114):
In Reply to: Farmall 504 Transmission posted by Investor 07 on January 04, 2007 at 11:39:52:
Operator's manual is correct, you just have not found it yet. On left side of transmission housing, three inches toward the rear from the joint of center trans. section and rear trans. section and about 9-10 inches down from topside of rear trans. top cover plate there is a hex head pipe plug screwed into the side of trans. housing . Screwed into this pipe plug is a small hex head bolt (7/16" wrench). Remove the small bolt and fill trans. housing through large pipe plug located on top of housing until fluid flows out small hole on side of trans. housing.
