Generator Pegs Ammeter!!
Posted by chadd on January 05, 2007 at 09:01:17 from (4.188.131.138):
Hi guys, I am still working on our W6 with the generator problems. I will go through the steps of what I have done: Original problem:Gen Wire came off of regulator and hit frame. Solution:Got new Regulator and had generator rebuilt. Disconnected battery, installed assembly, reconnected battery, jumped batt and gen terminals with wire to polarize Behavior:Would only reach the zero line at full throttle, otherwise drained. Solution: Sent generator and Regulator back to repair shop Behavior: After getting it back I disconnected battery,installed assembly,reconnected battery, polarized by jumping batt and gen terminals, Drained regardless of engine rpm or light switch settings Solution: Sent generator and Regulator back to repair shop again. Current problem: After getting it back, the gauge sits at zero when engine is off. Gauge is functioning, as it deflects when the lights are turned on. When tractor runs, ammeter is pegged at 30 amp DRAIN. Tried repolarizing, but has no effect. Tried switching to another old regulator that I cleaned the points on, did same thing, but when the tractor was shut off, it continued 30 amp drain until battery was disconnected (took about 2 sec to disconnect the cable)(I assume that means the points are stuck in it.) The guy at the repair shop told me it works fine with negative ground, but doesn't with positive ground on his machine. He suggested I reverse the electrical system of the whole tractor, which I told him I wasn't interested in doing. What the heck is causing this, should I just buy a new generator and regulator or go to a different rebuilder? The guy at the shop told me that he won't looking at it again because it can't be on his end. At the same time, I don't want to have to eat the cost of the rebuild and a new generator. Input Please?
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
