Re: Farmall M 12v electrical system
Posted by John T on January 06, 2007 at 09:25:34 from (66.244.90.5):
In Reply to: Farmall M 12v electrical system posted by Ponderosa on January 06, 2007 at 08:42:18:
Ponderosa, Sooooooooo many questions so little time lol lets start with the basics. 1) Most allllllllll alternators including those Delcos require NEGATIVE GROUND PERIOD so I wouldnt try n wire it up at Positive ground whatsoever. i.e. hook the batery up with its - post to frame ground and + to starter/switch BEFORE you install n wire the alternator. 2) The starter will still work fine n turn the same direction REGARDLESS OF POLARITY i.e. if you convert to neg ground to accommodate the alternator NO PROBLEM with the starter. 3) Assuming its the standard points n condensor battery powered coil ignition NOT an electronic ignition (which IS POLARITY SENSITIVE), it will work at EITHER polarity buttttttttttttt the coil works best if its wired to match the polarity i.e. if at Neg ground its + gets voltage from the ignition switch and/or any ballast while its - wires to the distributor. If at Pos ground reverse that with - getting voltage from switch/ballast and + to teh distributor. 4) In the event you need to change from pos to neg ground the ammeter leads need swapped or else it will read bass ackwards. It will work at EITHER polarity but if you change things the leads need reversed. 5) If youre at 12 volts the coil must be a full true 12 volt rated coil or rlse if you use a 6 volt coil it needs an external series voltage dropping (12 to 6) ballast resistor wired in after the switch and before the coil. 6) Many people use the GM 10 SI internaly regulated 3 wire 12 volt alternator wired n configured to work like a one wire unit, post back if you need wiring instructions. Hope this helps, post back any questions Ol John T and all in Indiana
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
