Re: Farmall M 12v electrical system
Posted by Hayfarmer on January 06, 2007 at 09:37:42 from (12.160.161.146):
In Reply to: Farmall M 12v electrical system posted by Ponderosa on January 06, 2007 at 08:42:18:
Not sure what you mean the tractor has a 12 volt ignition and starter. Most with the 12 volt conversion use the stock 6 volt starter and ignition with either a 12 volt coil with internal resister or a resister ahead of the coil. There is a 12 volt wiring diagram for the conversion in the archives done by Bob M. I used it when I converted my SMTA to 12 volts and many others here have done likewise. It should be negative ground. The starter will work fine on 12 volts, Don't crank the engine for too long with it. If you get a 3 wire delco alternator an follow Bob Ms diagram it should work fine.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
