Re: OT: Crappy Craftsman Toolcase
Posted by Janicholson on January 06, 2007 at 15:48:37 from (66.173.50.140):
In Reply to: OT: Crappy Craftsman Toolcase posted by JayWalt on January 06, 2007 at 13:24:46:
The HDPE is very weldable. I would get a henge made from HDPE from some other item, and weld it on around the preimeter, then spike weld through the middle every 3/4" or so. A pencli type soldering iron works well. Weld deep and mix the material fro each piece, and the filler material, as you go. Practice makes it a snap. Be sure to use 1/8" strips of HDPE for the filler material. YOu can probably weld ABS on to the HDPE as well, but it is trickier. Good Luck, JimN
