Re: IH 1586 Problem
Posted by Larry B 1486 on April 12, 2009 at 16:44:26 from (67.142.161.31):
In Reply to: IH 1586 Problem posted by AE on April 12, 2009 at 14:59:52:
Your engine oil cooler is leaking oil in the water. They run around $175.00 . Been there on my 1466 and 1486. You will have to flush out your radiator and motor. I have run a lot of water thru one to get it all out. Also you will have to change your coolant filter. I took my filter off several times and flushed it out and later when the water finley ran clean, put new antifreeze and a new filter
