Re: big motor in farmall m
Posted by Nat 2 on January 07, 2007 at 08:07:41 from (69.204.107.149):
In Reply to: big motor in farmall m posted by miracle child on January 07, 2007 at 06:20:23:
Right off the bat, I can think of a few problems:
1. Frame rails are too narrow.
2. Frame rails are too short.
3. Hood too short.
4. Grille, hood, tank too low.
You"re trying to fit 20lbs of manure into a 5lb bucket, and that is going to present some challenges. You"re pretty much going to be on your own in figuring out what to do, what parts to use. This is not a bolt-in operation, and as far as I know, has never been done.
I would start out by getting the rear engine mounting plate worked out so the engine is attached to the transmission. Then build the rest of the tractor around that.
Once you get it done, it"s going to be little more than a show piece, because the M was designed for 33HP, and IH started getting in trouble with that design at 60HP. A DT466 can put out upwards of 330HP, ten times as much as the tranny was originally designed to take! It"d tear the rear end up at an idle! Of course, you should de-fuel the DT466 as much as possible, and probably skip the turbo.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
