Re: big motor in farmall m
Posted by ChadS on January 07, 2007 at 13:18:48 from (66.228.96.243):
In Reply to: big motor in farmall m posted by miracle child on January 07, 2007 at 06:20:23:
Constant mesh gears breaking, cant keep them in 4th gear due to linkage flexing from so much torque. You would have more fun with a 560-806 type engines with a turbo and not have to worry much, and not have to do so much to put it in the M rear end. Id betcha a 560 flywheel with a M starter ring would let you use the stock M starter,,,, 560 clutch, with some sort of alteration to the clutch hub to fit the M input shaft,,,, unless, the M or SM had the same diameter clutch,, as the 560,,, then just use the M or Sm disk,,,, Thats using the 560 type motor,,, on the big block 6 cyl,,, its the same basic bellhousing bolt pattern,,, so if you can get the whole tractor engine, with the back plate, clutch etc etc,,, do some measuring with a M motor plate and see if it will fit. Id rather have the DT407,,,, Chad
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
