Re: is this right?
Posted by Bob M on January 08, 2007 at 07:27:09 from (151.190.254.108):
In Reply to: Re: is this right? posted by Pat-CT on January 08, 2007 at 07:03:16:
Hey Pat - That coiled resistor is the headlight dimming resistor. (And incidentally that flaking "paper stuff" on it I believe is asbestos...)
Anyway that resistor's presence/absence has no effect on the charging circuit. It only causes the headlights (which are already plenty dim!) to burn even dimmer when the switch is set to "L".
Note - If your tractor is now equipped with a voltage regulator the field resistor is not required nor used.
