Re: is this right?
Posted by Bob M on January 08, 2007 at 08:18:34 from (151.190.254.108):
In Reply to: Re: is this right? posted by Pat-CT on January 08, 2007 at 07:53:20:
Pat - The quick answer is yes. There must be a resistor in series with the field ciruit in order to provide a "low" charge rate.
However if your H has a voltage regulator the "low - high" charge function is being controlled automatically by the regulator.
Note there's a LOT of tractors out there that have had their OEM cutouts replaced by voltage regulators. The field resistor is then typically abandoned in place - or removed entirely - as it no longer serves any function.
