Re: 6Volt Starter
Posted by Bob on January 08, 2007 at 13:57:27 from (69.178.229.154):
In Reply to: 6Volt Starter posted by Mike Broome on January 08, 2007 at 13:49:45:
Either the starter is defective internally, the manually-operated starter switch is bad, or the starter gear and ring gear are jammed together.
Making SURE the ignition is OFF, you can put the tractor in high gear, and rock it back and forth, noting (by the fan) that the engine rocks back and forth.
If it still won't crank, check the manually-operated starter switch held to the starter with 2 swcrews (IF so equipped.)
If no problems there, the starter will have to come off.
