Re: Taking apart the governor
Posted by Brownie450 on January 08, 2007 at 16:02:10 from (207.177.82.171):
In Reply to: Taking apart the governor posted by Guff on January 08, 2007 at 12:46:57:
Do you leave the throttle at low[minimum] when the engine is shut down? Try leaving the throttle lever at its lowest [idle] position when you shut the engine off for the night & then opening it up again when you start it in the morning. Also try using a hair dryer pointed into the governor housing to dry things out while you have the cover off.
