Re: ID 4 Dozer
Posted by td5doug on January 09, 2007 at 14:58:56 from (207.200.149.63):
In Reply to: ID 4 Dozer posted by dej(JED) on January 09, 2007 at 06:04:50:
It would be a T-4, The smallest in a line of 3 built from 1959 thru 1964 at the IH plant in Hamilton Ontario Canada.
T-4, 123 gas 28dbhp, +- 5800 lbs
T-5, 135 gas 32dbhp, +- 6000 lbs
TD-5 144 diesel 30dbhp, +- 5900 lbs
In 1965 they became the 500 series, in late 1969 the 500C, & in 1975 the 500E. production ended in 1978.
