Re: 1940 H need the nitty-gritty
Posted by Wardner on January 09, 2007 at 18:47:48 from (206.148.21.16):
In Reply to: Re: 1940 H need the nitty-gritty posted by Wardner on January 09, 2007 at 18:29:11:
SKK
Seeing that you don't have an ignition, there is one little detail that you might miss. The kill switch is different on the early mags. Instead of grounding the mag with an electric wire, you need a mag mounted pull switch to kill the motor. The switch is connected to what looks like a lawnmower throttle cable and terminates with a brass knob at the rear gas tank mount. 90% of these switches have been tossed and the kill function converted to the later style. You will probably find an illustation of the switch in the parts book.
