Re: Checking Voltage of a generator
Posted by Roger Mills on January 10, 2007 at 11:09:45 from (64.122.113.206):
In Reply to: Re: Checking Voltage of a generator posted by John T on January 10, 2007 at 07:42:26:
John, here goes and I think this is correct, no real sensing in a cutout, coil windings do some-depending on the spring tension on the contacts. Some cutout relays energize when gen V comes up, and open when output current drops below limits. 3 brush gen has voltage from moveable third brush available to field coil, external hard ground is max field current so max available gen output at a given RPM. The brush is adjusted for rated ouput V under a specific current load. Gens like the ones on letter IH tractors were usually 20 amp rated max at 7.0 volts so a 0.35 ohm load. 2 post cutout does not have built in resistor and it may have been mounted external or in the light switch as these have. The normal wiring takes the field of the genny only to the resistor at the switch. When off the switch opens the resistor to ground circuit so no output. Can also happen if the ground is bad or the wire is broken. In the first detent the switch connects the resistor to ground and you get low charge, the next two detents turn on the lights and shorts the field to ground so you get high charge. 3 post cutout has a resistor inside that the field connects to. If the original switch is also connected to the field as well then you get low charge in off, med charge at first detent and high charge in 3rd and 4tn detent because there are two resistors in the circuit to ground. Off would be, say 1 ohm (the one in the cutout), L would be 0.5 ohm (both in parallel, and then D and B would be 0 ohm or shorted to ground. A VR has more than one relay contactor and their job is to sense output voltage and current loads. In the early two relay ones there is a separate LOAD contact that changes the output of the gen depending on the actual load. This is to help keep the voltage proper under varying loads. In later ones a third relay was added that is voltage sensitive and the load wire was connected to the ammeter again. I hope this is fairly clear, I tried to stay general and not get too tekky.
