Re: My H is stuck!
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Scott on February 04, 2000 at 20:18:09 from (209.130.131.40):
In Reply to: My H is stuck! posted by Jeff on January 31, 2000 at 06:57:26:
The reason the shifter rails come out of alignment is that when you went to shift , the end of the shifting rod slipped between the rails,before the rail reached it's full travel.The reason this happened is that the end of the shifting lever is wore , and needs to be built up to specs like farmer Bob said.As far as water in the transmission goes , a temp fix is : dump one gallon of antifreeze into the transmission untill you get around to changing the gear lube.We had a farmall "H" with the same problems.
Post A Followup
: Re: Re: My H is stuck!
