Re: Plugged Carb
Posted by Bob M on January 10, 2007 at 19:37:08 from (69.205.124.61):
In Reply to: Plugged Carb posted by Wishfull thinking on January 10, 2007 at 18:33:35:
Don't do it! Vinegar might work on a cast iron tractor carb. But the acid in vinegar will attack the aluminum in a chainsaw carb.
Better approach is to soak it in a good quality carb cleaner (Gumout, etc).
Or soak the carb in a paint remover or brush cleaner containing methylene chloride. This stuff quickly dissolves varnish but does not harm the aluminum. Just make sure you remove ALL non-metal parts (diaphragms, nylon bushings, etc) before soaking as they will disappear along with the varnish during the soaking process!
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the ... [Read Article]
