Re: How much does a Regular's engine weigh?
Posted by CNKS on January 12, 2007 at 06:49:07 from (204.249.178.32):
In Reply to: How much does a Regular's engine weigh? posted by Ludwig on January 12, 2007 at 06:38:27:
I think my hoist has a 1400 lb rating as a minimum. Slide in the lift arm and it goes up to 2250, then 4000. I think 1400 is sufficent, provided you are not trying to lift the whole front end including the front bolster off the ground. I would guess the engine weighs 6-800 lbs, I could be way off. You can remove the head first to lighten the load. If you are going to repair it yourself, out of the tractor, you also need an engine stand -- there it gets a little tricky, as there are big differences in them. More important than the entire weight you are trying to lift is the stability of the hoist/stand you are using. They will tip over.
