Re: Cub oil pump priming
Posted by gene (missouri) on January 13, 2007 at 21:26:18 from (64.85.223.20):
In Reply to: Cub oil pump priming posted by thebigron on January 13, 2007 at 20:58:53:
The oil pump is located on the left rear of the engine.
There is a plug on the left side of the engine. As your are standing on the left side of the engine the plug will be to the right of the bottom edge of the manifold.
The second location. Look inside of the oil filter housing. There is a hole near the top on the inside. You can use an oil can to put oil into either location.
