Re: Cub oil pump priming
Posted by jeffcat on January 14, 2007 at 09:50:43 from (216.107.36.145):
In Reply to: Cub oil pump priming posted by thebigron on January 13, 2007 at 20:58:53:
You can also use an oil tank . Same deal as a tire air tank but you but a little ball valve on it . Fill it with about one and one half quarts of oil and no more than 30 pounds of air pressure. You can unscrew the pressure gauge and hook a hose there. Open the valve and the whole engine is now oiled! Jeffcat
