Re: 706 crankshaft pulley
Posted by ejr-IA. on January 14, 2007 at 16:11:59 from (63.26.161.127):
In Reply to: 706 crankshaft pulley posted by super red on January 14, 2007 at 06:13:53:
You are talking german diesel right.This is out of a I&T book.Place one pressure ring on crankshaft with thick end towards engine.Install the wedge rings in pulley bore so that the slots in rings are 90 degrees apart.Slide pulley onto crank and align with timing pin.Install pressure ring,flat pressure washer and three cap screws.Tighten evenly to 55 ft.lbs.
