Re: Ether on a diesel engine
Posted by Dave Sherburne NY on January 16, 2007 at 14:58:12 from (170.215.197.79):
In Reply to: Ether on a diesel engine posted by dave2 on January 16, 2007 at 00:00:09:
I don't like to use it . I rebuilt a JD2640 a
couple years ago and three of four pistons had
broken rings. Boy did it smoke. That said, I have
been told to always have the engine turning over
as you give it a small squirt, thats where the
permanent mount with the tube to the intake manifold
is best.
